Stock Coil Vs. MSD Blaster TFI
RE: Stock Coil Vs. MSD Blaster TFI
well, my brother got a blaster tfi coil on his virtually stock 95gt and he said he notcice alittle bit of umph, i would also like to know the story and other gains from this because i will eventually need one.........
The MSD produces a bigger spark so you get a better combustion so you will see a difference but it will be minimal. Good upgrade to your ignition system i have one and it works great
im on my second one, something happend to my 1st i dont know what but it just did not run right so i got a new one it fixed the problem, also if you have a aftermarket tac dont hook it up to the coil it will fry your tac.
I don't see how just coil with high voltage output would help on a pretty much stock car. The most voltage that your spark plug is going to put out is 15kv. Your plugs are going to put out the same amount of voltage weather you have a 40kv coil or 48kv coil. The 48kv coil would be able to recharge better at higher rpms (6k and ^) because of its stonger magnetic field.
