TOO HOT!!!
TOO HOT!!!
Ok so I have been going through spark plug wires like nothing. I have burnt through 2 msd wires and a few other ones. The thing is that they dont ouch the header. I got pretty good at this after a little bit and I have no idea what to do about this. I heard there are some kind of socks that you can put on the boot anyone know of this? Or is my car burning too much fuel or what? TIA
RE: TOO HOT!!!
you could put some kind of cowl or scoop hood on it. it will lower underhood temps by prolly around 150 degrees as well as add some style to your car.
your motor is not running to hot is it?
RE: TOO HOT!!!
well just a thought here... too small of a plug wire? If its not touching anything then its burning up from either ambient heat, or internal heat. Here is my thinking... If you cross battery terminals with a wrench, if you cant get the wrench off one of them real damn quick, it will soon get extremely hot and probably weld itself on. If you take some small gauge wire and connect terminals, the wire will literally burn up right in your hands. I watched a kid do it, and he was holding it, and the wire literally went up in smoke and left burn marks... it was almost instant.
IF your running a high output ignition, and too small a wire(more resistance-> more heat) and an engine compartment thats hotter than usual, this might be your problem.
Just a thought here.
What size wires are you running?
Jim
Jim
RE: TOO HOT!!!
I believe they are 8mm I believe they are some ****ty ones. Maybe I will look into the MSD again and getting some sort of sleeve or something. Which MSD wires would you guys recommend I do have the blaster coil I forgot if they are heli core or the other ones.
RE: TOO HOT!!!
ORIGINAL: Crazyfast50stang
For the DD bosch is tops, good quality stuff, but not performance oriented.
ACCELL and MSD are both reputable, had good luck MSD 8mms
Do you think it might be related to heat from resistance? It was just a theory... ifyou havea burned plug wire cut it open and do some investigating...
Something like this maybe?
http://store.summitracing.com/defaul...=KeywordSearch
Jim
RE: TOO HOT!!!
It could be the resistance. I got the wires from pep boys and they arent high performance. I'll look into the accel and MSD. Thanks. Also i might look into a cowl. That would help a bunch I know.
RE: TOO HOT!!!
well we found your problem...
Haha seriously though, if you have a multimeter, measure the resistance of one of the current wires and have a buddy pull off an MSD or other high performance wires and measure just for HA-HA's... you might have found the problem or you might have to keep looking.
Jim
