rebuild help
Old Jan 10, 2006 | 06:55 AM
zkit18's Avatar
zkit18
Default rebuild help
I am rebuilding my engine. I have a new shortblock on the way. I am going to replace the cam but before I order new parts I need help figuring out how far I am going to go with the rebuild. I alread have a new 130 amp alt off a sn95, a windage tray, high flow water pump, and an electric fan off a volvo to go into the rebuild. My big concern is the fact that I am going to be driving this car across country so I need to keep the gas milage as high as possible but would like to add some hp while I am doing this. I already have cold air, MDS coil, equal length shorties, high torque starter, aluminum 3 core radiator. I have about $2000 I could spend but I need to keep as much of that as I can to help finance the trip. So the meat and potatos. Should I upgrade the h/c/i? Only upgrade the cam? Only upgrade heads? Only upgrade intake? If possible, give me name brands for your vote. Oh, and if you know any reliable mechanics in Hawaii in case I port and polish the heads, please let me know. Thanks.
Old Jan 10, 2006 | 12:06 PM
rsw007's Avatar
rsw007
Default RE: rebuild help
bite the bullet and do it all or dont do it at all.
Old Jan 10, 2006 | 12:19 PM
88BlueGT's Avatar
88BlueGT
ORIGINAL: rsw007
Well, I wouldnt say dont do it at ALL if not everything but I would def do it all if you can. Just do what you can afford.
Old Jan 10, 2006 | 12:23 PM
vfast's Avatar
vfast
I ♥ Acer
hell with the mileage ..get a 5 gallon gas can and a syphon hose
Old Jan 10, 2006 | 12:59 PM
mkspeed26's Avatar
mkspeed26
now that I think about it, I should have voted for nothing at all. i would save up for a trick flow top end kit
Old Jan 10, 2006 | 01:28 PM
91stang's Avatar
91stang
ORIGINAL: rsw007
what he said...
for the full upgrade i quoted myself out to $2120.71 which includes injectors, fuel ump, heads, intake, roller rockers (1.7), cam, t/b, and MAF
Old Jan 10, 2006 | 01:51 PM
stanglx2002's Avatar
stanglx2002
Since you want gas mileage then you shouldnt mod the car because that will lower the mpg. Buy a DD and mod the crap out of the car
Old Jan 11, 2006 | 02:40 AM
zkit18's Avatar
zkit18
ORIGINAL: stanglx2002
I can only ship one car from Hawaii so getting another car is not an option. I am going to rebuild it for the sake of reliabiliy. With a Cobra intake, 73mm mass air meter, 70mm polished throttle body, 24# injectors, adjustable fuel pressure regulator; what cam would you suggest keeping in mind I would like to keep the gas milage as high as possible?
Old Jan 11, 2006 | 08:56 AM
stanglx2002
ORIGINAL: zkit18
why do you need 24's with that combo
Old Jan 11, 2006 | 06:31 PM
zkit18's Avatar
zkit18
I thought if you upgraded the airflow you have to upgrade the fuel flow. Either way the cam is the only thing stopping me right now so any suggestions would be appreciated.
Dathan
Oct 5, 2015 05:52 AM
Drastang
Sep 30, 2015 03:48 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
8lug
Sep 21, 2015 01:33 PM
