fan too loud!
RE: fan too loud!
Here is a great instructional article about this subject. Check it out it should answer all your questions.
http://www.fordmuscle.com/archives/2...cfan/index.php
RE: fan too loud!
well, u have a '91, so u must be hearing the same thing as me, the fan just pushes alot of air out and is SOOOOO freakin loud! i really want to know how to make it stop. i know its not the fan clutch. the air pump huh? i'll have to look into that. does it bother u?
RE: fan too loud!
if you decide to stay with the stock fan there are two types of clutch fans.the one you have sound like an rpm one which the faster your motor spins the louder it gets and the tighter it gets.you need the one that reacts by temp which when your motor get warmer then the fan loosins up and spins more freely(alot more quiter).
RE: fan too loud!
ORIGINAL: ballzoutstang875.0
air pump? do you mean the smog pump? i don't think that it would make that much noise.
disconnect the fan and see if it still makes that noise.
RE: fan too loud!
yeah, smog pump. my '87 didnt have one so i dont really know if its making that noise. i will try disconnecting the fan and see what happens though. i do see what ur saying about the two different fan clutches, i'll look int it. thanks
RE: fan too loud!
dude, try changing the engine coolant teperture senser, mine did the same thing, it was running on hi all the time , because that stupid senser was bad! that is prolly why yours is so loud.. well let me know if this help's!
KingRando
10-02-2015 08:06 AM
09-25-2015 09:06 AM
