Underdrive pulleys and AC delete
i found this kit on LRS that comes with a 3 piece underdrive pulley kit, an AC delete kit, and it also bypasses the smog pump
http://www.latemodelrestoration.com/...0%201&comp=LRS
i just have a few questions before i buy it.
since it bypasses the smog pump, can i take it off after im done and is there more to it than just unbolting it
also does this relocate the power steering and what does that involve
and this should work on a 351w i just might need a different size belt right?
RE: Underdrive pulleys and AC delete
You can remove the somg pump after the short belt is installed...you will either need to remove the smog tubes from the back of the heads and block the smog passages off or just block off the tube itself and leave it bolted up to the heads...and the frpp kit is one of the cleanest and very easy to do the only thing it does is replace the ac bracket with the supplied bracket and is a quick bolt up and then your done.
cool cant wait to get it and put it on. i guess ill get 2 belts, a short one for driving around, and a longer one for when i get my car inspected. or has anyone passed without the smog?
