Optima Battery
Old Jan 19, 2006 | 07:09 PM
stanglx2002's Avatar
stanglx2002
Default Optima Battery
With the dry cell Optima batteries do you have to put it in a sealed box i wouldnt think so you should just be able to bolt it down
Old Jan 19, 2006 | 07:11 PM
BraMas's Avatar
BraMas
Default RE: Optima Battery
YOu will be fine just bolting it in the normal spot.
Old Jan 19, 2006 | 07:25 PM
marx91's Avatar
marx91
bolt it down where? do you mean in the trunk? or normal spot?
stanglx2002
im putting it in the hatch with my custom sub box im going to make
Old Jan 19, 2006 | 07:35 PM
marx91's Avatar
marx91
if your going to race at a drag strip it will have to be in a sealed box
but if not i guess you can do what ever you want, i'd would find out
about inspection issues, they might not pass it if it not in a box
Old Jan 19, 2006 | 07:40 PM
stanglx2002
its going to be in the trunk on the car. Optima Batteries are dry celled so their shouldnt be a problem
Old Jan 19, 2006 | 09:35 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: stanglx2002
Your there should'nt be a problem, but they can fail you at tech, even though it's a sealed dry cell. I would put it in a box just to be sure.
Old Jan 20, 2006 | 12:01 AM
stanglx2002
thanks i will put it in a sealed box anyways
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
mdj89
Oct 8, 2015 09:16 PM
logan409
Sep 26, 2015 07:43 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
