Tranny Swap Question
Old Jan 19, 2006 | 11:02 PM
l_o_t_s_r's Avatar
l_o_t_s_r
Default Tranny Swap Question
I appologize if this has been asked before but I was wondering what needs to be done, what parts I'll need and all that fancy stuff to do a swap from Automatic to Manual transmission in a 1989 Ford Mustang GT Convertible.
Old Jan 19, 2006 | 11:07 PM
cammedlx's Avatar
cammedlx
Default RE: Tranny Swap Question
Tranny,bellhousing,crossmember,driveshaft,clutch cable,brake/clutch pedal assembly,clutch,shifter,clutch fork,TO bearing,flywheel,pilot bearing that should be about it...and you will need the shift boot and a manual cover...
Old Jan 19, 2006 | 11:11 PM
philthy89fifty's Avatar
philthy89fifty
you don't need a crossmember nor will you need a driveshaft.you will need in adition a t-5 back up light wiring harness a speedo gear for a t-5.clutch cable retaining clip.
Old Jan 19, 2006 | 11:15 PM
cammedlx's Avatar
cammedlx
Um your right about that...oops got ahead of myself there...but i always thought the yoke was diff. on the aod's and t-5's
Old Jan 19, 2006 | 11:48 PM
l_o_t_s_r's Avatar
l_o_t_s_r
have either of you done this swap? just curious and how much would I be looking at spending roughly?
Old Jan 20, 2006 | 04:41 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i didnt have to do any wiring changes other than unplug the aod ext harness under the car and what was left of the harness plugged into the t5 and my backup lights work my car is a 91 vert gt though!
Old Jan 20, 2006 | 06:02 PM
nitrous_bob's Avatar
nitrous_bob
try this...excellent site
EDIT*********** oops maybe i should give you the link...lol
http://www.westcoastfords.com/articl...ap/t5swap.html
67LimeCoupe
Sep 30, 2015 04:46 PM
04stangman
Sep 17, 2015 01:45 PM
97SN95GT
Sep 13, 2015 09:45 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
