351 Cleavland vs Windsor...
Old Jan 22, 2006 | 02:46 AM
kartracer55's Avatar
kartracer55
Default 351 Cleavland vs Windsor...
WHATS THE DIFFERENCE!?!?!?!?
Which one can handle more power etc...
Thanks
Jim
Old Jan 22, 2006 | 02:50 AM
Black Snake's Avatar
Black Snake
Default RE: 351 Cleavland vs Windsor...
Ones a big block the other is a small block.
Clevland is Big Windsor is small.
Old Jan 22, 2006 | 02:52 AM
kartracer55
ORIGINAL: Black Snake
Is the cleavland a stronger block?
Old Jan 22, 2006 | 03:03 AM
Black Snake
Yeah. Its a "Big Block" Any big block will be stronger than a small block.
Old Jan 22, 2006 | 03:08 AM
kartracer55
Ok, I wasnt sure... you were refering to the overall size of the block not the displacement
Thanks
Jim
Old Jan 22, 2006 | 03:11 AM
Black Snake
Same displacment but ones a bigger block.
Old Jan 22, 2006 | 03:14 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
both are small blocks!!!the cleveland has smaller main journals can turn higher rpms and is a torque god!!cleveland down fall is that they havent been made since 1974
Old Jan 22, 2006 | 03:15 AM
kartracer55
Cool, thanks for the info. Ive heard the 351w is almost the same size overall as the 302, is this true or do you need extensive modding to swap them?
Jim
Old Jan 22, 2006 | 03:18 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the windsor is taller by a couple of inches and wider by a couple but the same length
Old Jan 22, 2006 | 03:20 AM
kartracer55
ORIGINAL: rmodel65
Id need an aftermarket hood then right?
