is my set up right for a super charger
ok my buddies want me to put a super charger on my pony....but im not sure i got the right set up for that yet.....i dont know much about super chargers, but i was wondering if you all could tell me if my set up is good for a sc or if i need to make some changes like intake and heads or cam maybe....right now im running a cobra intake and gt 40 heads cast with some minor porting and im running the e303 cam....do you think that will work or do i need a better set up...and im running stock fuel system....any help on this would be greatly appreciated....thank you....
RE: is my set up right for a super charger
ORIGINAL: 91stang
if you wanna run more than 8 psi in your sc you need to get forged pistons and what not?
Just swap injectors and add a fuel pump and you'll be okay.
^ Agree, you should be OK with that setup. I will be necessary to upgrade the fuel system but w/ everything else you will be fine. Also, you might want to look towards a better cam to fit your needs. The E-Cam will do fine but you could do better.
it all depends on how hard you are on youre engine. plus 8-10 is a safe boost for stock motor. notcie the word safe.
i remember a vid i saw of someone who broke a connecting rod on his block because he was runing too much boost on a stock block. he was beating a ricer or soemthing then it blew
yes my car has already been converted to mass air but i dont have a good mass air meter yet....i wanted to wait and get the maf and fuel injectors at the same time....what size injectors would you recommend....i will dig out my stock pullies and put them back on....i will make sure i run and 8 to 10 boost sc....i aint trying to blown anything up....and 88BlueGT said i might want to change my cam what would you all recommend for a cam with a sc.....and thanks again for all your help.....
i'd go up to 30lb injectors at least, as for a cam you might be better off getting a custom ground cam
from lunati or someone like that, but i think tfs has a nice blower cam off the shelf
30lb injectors would be a minimum for your combo. 42s would give it some room to grow if you wanted to upgrade heads later. The TFS Stage 1 makes a decent blower cam and is a little better than the Ford F cam that costs roughly the same. For the next higher step in cams, an Anderson B series cam is nice (just don't buy an Anderson believing you're buying a custom cam -you're not). For another ~$30 more, a custom cam would be ideal.
A Vortech SC or Paxton Novi 1000 are both entry level blowers in the same price range. A Vortech S trim would be the next step up and is a good blower also.
Go with a Pro-M meter to match whatever injectors you buy.
And I was assuming you were already mass air because the E cam isn't SD friendly.
