Sunroof
Old 01-24-2006, 09:12 PM
Shifty5.0
I ♥ Acer
Shifty5.0's Avatar
Default Sunroof
I was wondering if anyone is having problems keeping their interior dry when it rains? I have a sunroof in my car, and water seems to pool up there then leek down throught my headliner. It then drips onto my seats....
Also the seals on the door are leeking, the door looks straight but it still pools up and into my car. Anyone else having similar problems? or knows a solution?
Shifty5.0 is offline
Old 01-24-2006, 09:21 PM
uedlose
uedlose's Avatar
Default RE: Sunroof
For the sunroof you should check the drains they might be stoped up and /or the seal could need replaced and the same for the doors the seals may be getting bad also are the hing pins worn out on the doors that also makes them leak at times
uedlose is offline
Old 01-24-2006, 09:56 PM
1990mustanggt
1990mustanggt's Avatar
Default RE: Sunroof
There are four rubber drains connected to the sunroof under the headliner. Sometimes they shrink and come loose from the sunroof. All you need to do if they came loose is reconnect them. If they are clogged up, just run something down the tubes to clean them out. It's a simple fix. If your doors are leaking, try replaceing the door hinges with a hinge kit. http://www.latemodelrestoration.com/...-KIT1&comp=LRS It's another easy fix. You could also do what I did and replace the weatherstripping. Here's a link http://www.latemodelrestoration.com/...t_50_home.aspx
1990mustanggt is offline
Old 01-24-2006, 10:43 PM
Shifty5.0
I ♥ Acer
Shifty5.0's Avatar
Default RE: Sunroof
alright, thnx for the help
AZ Redfire
07-23-2011 07:44 PM
floydfan
06-29-2005 07:31 PM
cool66
03-22-2005 01:27 PM
Mortl24
02-21-2005 11:29 PM
kkspeed
08-04-2004 02:41 PM
Quick Reply: Sunroof
