How much $$$ into your car?
RE: How much $$$ into your car?
Well, the first time I tried to build my car I put about 4K into it. The second time about 2K and now Im on the third time and now Im doing it the right way and im going new motor, trans, rear, suspension, fuel, ignition, interior, body, paint, etc. I will be buying my motor in the next month or two so by that time so far I will have 13K. And its just a start. AND I WONDER WHY I DONT HAVE MONEY!!!
jasper 308 installed 2500 347 stoker 2076 (with machine work done) head work 600 track heat intake 450 rr 200 valve springs 100 tb 200 cai 150 mas 259 cam 250 smog pump delete 50 ac delete 50 pulley's 110 lt's 289 ORHP 120 flowmasters 150 fuel pump 120 fpr 100 chip tune 300 nitrous 210 timing chain 70= 8354 in motor but i am prolly forgetting something
pro 5.0 200 centerforce dual frition adjustable clutch quadrant and firewall adjuster 500 traction bars 179 ca 110 subframe connectors 100 lowering springs 220 3.73 100=1409
in all and missing a few things probably 9763 almost 10000
a lot of money for a car i bought completely stock
Engine from Recon Automotive: $1700 (302 bored .040" over and rebuilt with new everything except rods, block, heads, and crank (all machined) dyno-tested (238.9hp/302.1ft/lbs tq with a carburetor on it) and broken-in and shipped all for that $1700)
Flowtech Headers: $150
Mac H-pipe: $160
Flowtech Warlock Mufflers: $150
Tranny Built by Mace-O-Matic Transmissions in Belton: $1675 (includes improved torque converter and shift kit)
Ford Racing Injectors: $200
Autometer Oil/Water Gauges w/ Ford Racing pillar pod: $120
Faze Air Fuel ratio gauge with Sunpro Gauge holder: $60
Bendix OE brakes all around: $600
Engine Install (for warranty purposes): $800
Walbro Fuel Pump: $80
Fog Lights: $30 (aftermarket, not OE)
Ultra Clear Headlights: $170 (laugh all you want, between the utlra clear lenses and Sylvania Silverstar bulbs I can see three times further!)
All of that's just in the GT. Don't ask about the II or my Truck, they're cheap compared to that and faster! lol.
Mac H-pipe: $160
Lets see: 1991 GT Red, 5 spd, New Engine, Convert. Motor Mounts, heads, cam, roller rockers, intakes, cold air, headers, H-pipe, Flowmaster cat back, high volume oil pump, bosch water pump, flex-a-lite, edelbrock adj. timing set, mallory hardened push rods, Superior 4.10 gears, springs, MSD ign. (TFI, Wires), BBK Throttle Body/EGR spacer, Vortech MAF, New balancer, timing cover, and a new set of tires = appx. $10,000
The only things I have not touched are the pulley's, drive shaft, and control arms.
I paid $3500 for the car with a good interior and was completely stock though. I have about $7400 in parts for my car now and about $5000 or so to go into it to finish it. I have way to many mods to list but put it this way there is almost nothing left stock on this stock anymore. For list of mods click here
ORIGINAL: im_stuck_in_iraq
screw the srt4s ill stomp them...they are a ricer...dont go that way...please....lol
im_stuck_in_iraq, with what kind of car you have and your mods, you will be about a whole second or more slower than one. So you wouldnt stomp them.
