need help with autometer tach
hey...i have an 89 5.0 lx.i got the phontom tach and need some help putting it in. i no this is a stupid question but where can i find my ignition switch harness. is it underneath the steering wheel?i know tht i have to splice the white wire into the 12v but im having trouble finding the right wire...someone help me for the lov of god. Any help would be greatly appreciated..thanks a lot
http://www.veryuseful.com/mustang/te...itchWiring.gif
This will probably help
If not, then check http://www.veryuseful.com/mustang/tech/engine
Go through the site and look at the other diagrams
You're looking for a 12v signal wire that is activated in the Key On engine Off sequence huh?
I actually used the signal wire from my radio (advice from roundman, which btw; where has he gone to?)
But you should try to find the wire it calls for, with the diagram(s) it should be easier
sry and i dont meen to steal the thread, but i have a monster tach, would any of you guys mind telling me where im supposed to splice the white, green, red (and im assuming the black goes to a ground) wires go too? again im sry and i dont meen to hyjack your thread but its in the same topic
https://mustangforums.com/m_726992/m.../tm.htm#726992
I used the search function [&:]
No but seriously, check the instructions if you've got them; if not try the manufacturers website
after that, try searching on google
I don't remember off the top of my head or I'd tell you where they are
bryan616fl
Jan 25, 2019 09:07 PM
