Bad Idle Problems
On my 93 gt with the mods in sig I have a idle problem A very bad one
When the motor is cold I will fire it up and it will bounce around and then get to a Steady Idle
Then after driving it around some Up to temp I come to a light and It starts Boucning around like a few hundred rpm like 500-1200rpms I cleaned the iac adjusted tps set idle checked for vacuum leaks intake leaks found None that i could notice
I bought the Iac Adjuster kit from ford with No luck
Im sporting a bbk Throttle body 70m Pro series or whatever It has no hole drilled in it for idle air to go through
Any ideas Fuel pressure stays the same whe its bouncing around I think Ill hafta get back to you on that one
You might want to follow these procedures regarding maintenance and calibrations setting. Also recommended is to do a KOEO self-test and a KOER self-test too. This will help checking if the system has any codes (ECT, IAT, O2...) that could be causing the idle problem. LUK what you find out.
musnicki
Sep 23, 2015 07:11 AM
