whats the vibration??
Old 01-30-2004, 12:48 AM
Pitviper100
Pitviper100's Avatar
Default whats the vibration??
its does it while im in gear accelerating if im just cruising not speeding up at all in the 30-45 mph range it doesnt viberate but when im accelerating from 30-45 mph it does and then stops after about 45 mph
Pitviper100 is offline
Old 01-30-2004, 05:28 PM
mkspeed26
mkspeed26's Avatar
is it the road that you are driving on?? *L* i was thinkin the same thing when driving my dads pt cruiser cause it would always ahve a little vibration at a certain place, it is just the road is weird there. </P>
i dont think that it is something out of balance because it would vibrate even more when you speed up.</P>
mkspeed26 is offline
Old 01-31-2004, 01:41 AM
yardbird
yardbird's Avatar
Make sure your driveshaft bolts are all tight where it meets the rear.
yardbird is offline
Old 01-31-2004, 02:02 AM
Glengemen
Glengemen's Avatar
An easy way to see if you have thrown any weights is to get under your car and look at the driveshaft. You will be able to see if the weight is gone off the driveshaft. The cheap way to fix it is with hose clamps with the adjuster on the place for the weight. While you are under there check for any missing weights on your wheels and looseness in the drivetrain. Just start exploring all the moving parts down there and you will find it.
Glengemen is offline
Old 01-31-2004, 02:12 AM
nemethjames1
nemethjames1's Avatar
so your saying at around 35 mph in 3'd and 4th gear? what gears do you have in it right now? sounds like to me that you should be in second gear at 35 or so or it would be lugging... im not sure though
nemethjames1 is offline
Old 01-31-2004, 03:15 AM
Glengemen
Glengemen's Avatar
You got a good point. That didn't occur to me.</P>
Try being in second when accelerating, and report back.</P>
Old 02-01-2004, 05:12 PM
Pitviper100
ok guys ifound the problem... it was running crappy cause of the 02 senors so i replaced em runs great... the vibration is from bad u-joints though so im gonna get em replaced this weekend good to knnow my \stng is still goin good
