Heads and Upper and Lower
a buddy of mine might sell me this Upper and Lower Intake and hopefully his heads, i never attemped sometihng like this, i would deffinitally have some1 to help me with it , but how long do you think it will take and is it as hard as it looks? Theres like a shlt load a plugs eevrywhere i just would hope i remeber where everything goes .....
RE: Heads and Upper and Lower
its not really as hard as it looks i am doing the same thing myself right now. when i took all the bolts out i put them in a bag and labeled it that way i knew exactly where it went maybe it real easy when i went to put it back together
Yeah....take your time.....label everything...dont let anyone tell u not to do it that way...may take longer but makes it alot easier to get it back together and not have any extra bolts!!!
Yeah be patient, you need to label all your nuts and bolts, and parts.
Be sure to clean the cylinder surface real good with light sandpaper.
It took me about 2 days to do my swap. A day to dismantle and a day to put back together.
If you are even slightly mechanically inclined, you should be just fine doing it yourself. Like everyone said, LABEL EVERYTHING and keep it organized. Also getting a Haynes manual would probably help you out.
ORIGINAL: gspfunk
i also did the parts in bags and labeled them, and you could also take a few pics
of the motor before you tear it down, then you can refer to the pics for where sensors
go and what not, its not all that hard
Yeah i was thinking about taking pictures and definitally labeling everytihng and marking the plugs so i dont 4got where each goes .... Its a Trick Flow Track Heat upper and lower , and he thinks " not sure" Twisted Wedge Heads, idk how to tell tho, im positive there aluminium tho ....
The kid i might be buying them from Blew a head gasget and cracked his block right down the middle , anyway i offered him 600$ and he said he will think about it , he might throw in his rockers , pushrods , brand new lifters , 24 lb injectors and valve covers ..... thats a friggin deal ..... Wit That combo , Full exhaust . TB and stock cam , ... With a good tune do you think i can make about 300 wheel?
