mustang
Old Feb 2, 2006 | 12:32 PM
Mike14's Avatar
Mike14
Default mustang
http://washingtondc.craigslist.org/car/130157591.html worth it?
also what numbers would that car make and what times would it do?
btw he just wants over 4k for it
Old Feb 2, 2006 | 12:44 PM
HACKGT350's Avatar
HACKGT350
Default RE: mustang
looks nice i would be all over it if i were you
Old Feb 2, 2006 | 12:46 PM
92hatchLX's Avatar
92hatchLX
Default RE: mustang
Jump on that, see if you can get him talked down to 6,000 for it!
Old Feb 2, 2006 | 12:50 PM
Low_5.0's Avatar
Low_5.0
Default RE: mustang
looks good...i'd buy it....i've often thought of selling my 95 and getting an FOX GT....but i dont think i could get enough money for mine!!
Old Feb 3, 2006 | 01:03 AM
Mike14's Avatar
Mike14
Default RE: mustang
hey guys did that 92 Lx have airbags? also what do these 5.0's run with this gt40 and cam?
Old Feb 3, 2006 | 01:10 AM
FullAuto's Avatar
FullAuto
Default RE: mustang
It's a 4cyl converted carb car. I'd pass just because of that for that price. If it's a Ford crate motor, it has hypereutectics also. It has different buckets in it too. You need to check if it has an 8.8 or 7.5 rearend if you are serious. That is by far not a $6k car though.
Old Feb 3, 2006 | 01:14 AM
FullAuto's Avatar
FullAuto
Default RE: mustang
Well the reserve on Ebay is met at $4450. So bid now if you want it. I bet it was met on the first $3999 bid. I would have put it in the $3500 range.
Old Feb 3, 2006 | 01:18 AM
Mike14's Avatar
Mike14
Default RE: mustang
I live near this guy i wouldnt even bid on it I would just go down and get the thing and look at it....so if I do go look at it this weekend what should I look for as far as abuse, if its taken care of, and if all the components for the conversion are correct. Also what was differnt between the Lx 4cyl and the LX 8cyl beside motor (transmission, drivetrain, engine components, interior) also did driver side airbag come standard in the LX?
Old Feb 3, 2006 | 01:22 AM
FullAuto's Avatar
FullAuto
Default RE: mustang
Airbag came standard from 1990-up.
Old Feb 3, 2006 | 01:28 AM
FullAuto's Avatar
FullAuto
Default RE: mustang
The tranny was different, but since it's and AOD it was probably changed so it would bolt up. The rearend was a 7.5 in the 4cyl and 8.8 in the V8. The suspension and brakes were different. The fuel lines were on the other side of the car also. I doubt they changed the suspension, brakes and fuel lines. Since they went carb, they went the cheap route. The fuel line is probably ran with rubber hose across the front of the rack to the passenger side. I've seen this done often. That's if they just didn't put on a mechanical pump and run all rubber hose to the front of the car. In fact, I'd check the firing order to see if it's even an HO motor. Converted cars can be done so they are harder to tell, but when I see people go carb, it just screams to me they took the cheap route.
