Bent Frame
Bent Frame
When i first got my car about two years ago, i hit a curb really hard on the front right side of my car. No ones ever been able to align it right, it pulls and shakes just a little and i can tell by the way my tires wear it isn't completly right. Have any of yall ever done this? Anyone know how much to get it fixed?
RE: Bent Frame
if you plan on getting it fixed you might as well find a diff car, to get your frame straightened is going to cost you more then you would realize, they have to strip it completely down and straighten the frame. my frame isnt bent mine pulls a little to the right more then a brand new would, but the gaping between my front tires & fenders arent right, i dont believe my frames bent anyways. i just need to have my tires aligned & rotated, and i think maybe my struts, rods or my bushings may be bad, but all are replaceable.
RE: Bent Frame
chances are the youre subframe isnt bent!!! its more like the A arm or the K memeber. its very easy to bend a K member they are stamped steel pieces that weigh alot and bend very easy. to check i would take a center to center wheel measurement. when i hit a hill side and then had my car straighten. my k member was still off. it was off 1 1/8' of and inch back on the driverside
you dont need the car completely stripped to get a frame pulled, also stangs have subframes and you could just get a new front half put in if the car was worth it.
RE: Bent Frame
frame labor around here is 40+ hr with 2 hr set up but most body shops could pull it for you without any problems and maybe you might have to take the front clip off and maybe not.But just like Quik said it maybe just the k-frame or the control arm. the under side of the car has factory control points that you can measure from after you do a wheel base check if you put it up on jack stands and look under the car from side to side you will see holes that are in the same place side to side measure from the hole to the k-member then do the same on the side that got hit to see if the K is back.
RE: Bent Frame
i bought a smashed stang but im not gonna sell it.
im just gonna get it fixed tho.
built engine, body has low miles, and sumone at my bar
owers a body shop so hopefully i get a good price.
and it took me a long time to find an 83 stang so im not gonna let it go.
RE: Bent Frame
mine pulls to the right under hard accel, but i think it is just bushings, like everyone else said, it may not be the frame, look at the rest of the stuff under the car. yours is not bent mine is bent
[IMG]local://upfiles/11994/AA2E3FF59B5E40DF81A06D6AF65F7D0D.jpg[/IMG]
