How difficult is it to install the msd ignition
If i get around to it today i might start installing my 6AL ignition box. I bought the box, coil, and super conductor wires. The only thing im worried about is hooking up everything correctly to and from the box. Anyone have any tips or things to look out for? thanks
RE: How difficult is it to install the msd ignition
They have the easy plug and play harness which eliminates the worry. You may want to check on summit. Also the coil takes 3 minutes to install. With the wires make sure you get a spacer and keep them away from the headers or anything that gets hot and you should be on your way.
TfcCDR
09-14-2015 12:08 PM
