Thermo LEAKING!!!
Old Feb 2, 2004 | 01:01 AM
Ormist's Avatar
Ormist
Default Thermo LEAKING!!!
I installed a new thermostat today and when I started my car it started to leak. It did this the last time I installed one into this car, it leaks for about 20 minutes untill the gasket gets hot enough to fuse to the metal. Now to my knowledge its not supposed to be doing this, so why is it leaking? I put the gasket on the elbow side, not agianst the engin. And I dont have chrome or anything..
Old Feb 2, 2004 | 02:24 AM
Black Horse's Avatar
Black Horse
use some RTV</P>
Old Feb 2, 2004 | 02:55 AM
Ormist's Avatar
Ormist
Whats RTV? And if its not supposed to be leaking I realy wanna find out why its leaking... I cleaned the metal fairly well, so there wasnt any pieces of the old gasket on the metal any more. I couldnt get the smaller hose off so I had to slide the elbow to the close position in a tight space so the gasket may of moved i guess... but this happened both time I changed the gasket....
Old Feb 2, 2004 | 07:03 PM
619socalstang's Avatar
619socalstang
SILICONE boobies
Old Feb 2, 2004 | 10:26 PM
makarovboy's Avatar
makarovboy
You may have to use a large screwdriver to get that small hose off and on by prying on it. I haven't yet found an easy way to do it, but in order to have a least some decent access to the housing and stat, you need to get it off.
You don't need a gasket sealer, rtv or otherwise if everything is clean. I've never used any and (knock on wood) have never had one leak.
Old Feb 2, 2004 | 10:41 PM
Ormist's Avatar
Ormist
I fixed the leak, I bought a new thermostat houseing which fixed the problem.
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
