Next mods??
Old 02-02-2004, 07:31 PM
92 StangBang
92 StangBang's Avatar
Default Next mods??
Ok well first i would like to ask a question regarding my transmission and shifter. I havea tremmec TKo tranny and a pro 5.0 shifter. on the 1rst-2nd shift it seems like the shifter clicks from 1rst. stops for a second inbetween then into 2nd... It does this 95% of the time its not really slow but it takes a tiny bit long.. is this normal.. Sometimes if i try real hard it will either slide in easier or grind... so idk.. Also i would like to know what u would suggest as my next mods.</P>
1)Mac upper and lower control arms and steedasubframe connectors</P>
2) New Tires (sticky street tires not DR i need sum life) idk recomend sum, and autologic chip</P>
3)autologic chip and aluminum driveshaft</P>
92 StangBang is offline
Old 02-02-2004, 07:38 PM
Quik
Quik's Avatar
Default Next mods??
your shifter may need adjusted. check the stops on it. i would go with a stiff suspension first. why make power if you cant plant what you currently have already. you can get some life out of a set of DRs around 10k i think. there like any tire you run hard and they wear fast. i wouldnt get a chip untill you really need one.
Quik is offline
Old 02-02-2004, 07:46 PM
92 StangBang
Default Next mods??
well the tranny and all was done be a profesional shop..idk i think its just me.. what would an aluminum drive shaft do for me?</P>
</P>
Old 02-02-2004, 08:36 PM
mkspeed26
mkspeed26's Avatar
Default Next mods??
saves weight. thats all. if you want to look at suspension stuff go to www.**X****motorsports.com. i know it has a bunch of * thingies on it, it is only cause some moderater is being a pr**k and doesnt let us advertise them, for some reason.
mkspeed26 is offline
Old 02-02-2004, 08:45 PM
Quik
Quik's Avatar
Default Next mods??
the aluminum drive shaft lessens weight and has stronger Ujoints then your stock driveshaft
Quik is offline
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
TimeLord101
10-01-2015 06:40 AM
Quick Reply: Next mods??
