D&D K-Member
D&D K-Member
Hey everyone,
I ordered a D&D K-Member about a 3-4 weeks ago but one huge thing that I forgot to mention was that I was going to be running a 351W with it. Does it make a difference? Also, anyone who has had any personal experience with them I would like to hear from you. Thanks alot.
Dan B.
Dan B.
RE: D&D K-Member
No experience, but what I do know is that they are a little heavier....not by much though therefore that should write out that problem, as well the motor mounts are the same on the K member for 351's and 5.0's All ford vehicles in general are they are slotted you can run whatever engine you want.....We put 390's in a 302 frame, 351 in for a 360, 351 C swap to a 460, all in trucks and one in a old LTD....... everything bolted right up! We used to play alot as kids I still have that 351 C block at the farm I should go and get to play with!
RE: D&D K-Member
There shouldn't be a problem since the only difference between a 302 and 351 is the deck height and width. That's why the timing chain, cams, etc are the same dimensions. The motor mount bosses are the same width and placement.
