Drivesahaft
Old Feb 8, 2006 | 07:08 PM
Mustangkiler's Avatar
Mustangkiler
Default Drivesahaft
How much does a lighter aftermarket driveshaft really help? upgrades are endless on any car, but is a driveshaft even worth the money, just curious to get some opinions?
Old Feb 8, 2006 | 07:31 PM
865.0trunk's Avatar
865.0trunk
Default RE: Drivesahaft
its not so much about how much power it will give you. a lightweight drive shaft would fall under the same category as underdrive pullies and lightweight flywheels. they all reduce rotating mass which allows the engine to rev up more freely i dont know if it is worth the money you pay but they aretn that expensive on summit racing.
Old Feb 8, 2006 | 07:45 PM
gspfunk's Avatar
gspfunk
I would do some chassis stiffening and some other suspension mods before I'd worry about upgrading your DS. If the body/chassis has a lot of flex, you won't benefit any from lighter DS.
Old Feb 8, 2006 | 10:15 PM
393Bird's Avatar
393Bird
I agree, a aluminum drive shaft is something that should be done after most of the other things are done, since it is not cheap, and benefits are small in comparison to others that you could use the money on. If you go to 4.10 or lower gears, a aluminum drive shafts benefit goes up some to reduce drive line vibration you will get from the much faster turning shaft. I have been working on my project car for 3 years, and just installed a aluminum drive shaft last week. I am running 4.30 gears. I weighed the 2 shafts, and the aluminum one is 9 lbs lighter.
Old Feb 10, 2006 | 12:24 AM
Mustangkiler
Good job captain obvious, i know its lighter, i was just wondering if anyone has noticed a track time difference after changing there driveshaft, yes im sure it does help, but how much, because i just put 4.10 gears in my car but i know and have had experience with how much that upgrade helps, i am not one to buy a part that really aint worth the price less its mostly a strip car.
Old Feb 10, 2006 | 12:32 AM
ricepatrol's Avatar
ricepatrol
Hey dude, you should lay off a bit; they are trying to help YOU out, so don't get snappy [>:]
Old Feb 10, 2006 | 01:00 AM
91lxstang's Avatar
91lxstang
whats with the attitude they answered ur question by saying the arent worth the money which prob means they dont help out much for power, track times or any of that.....
Old Feb 10, 2006 | 01:17 AM
88BlueGT's Avatar
88BlueGT
And what the f*ck is up with your name.. MustangKiler ??? What kind of bullsh*t is that?!?
Old Feb 10, 2006 | 01:27 PM
gspfunk's Avatar
gspfunk
ORIGINAL: Mustangkiler
You didn't say what you have done to your suspension...if you've already done all your chassis stiffening, then get one. If not, then spend your $ on that.
Old Feb 10, 2006 | 01:34 PM
1BADASSLX's Avatar
1BADASSLX
i had a frpp shaft in mine for about a year but i think it was sh_t no good and cost to much money so i sold it on ebay and had a real one made here @ my work! also thought it had a vibration!
