What gears do I have?
02-09-2006, 01:24 AM
I finally went and grabbed the axle code off of my door tag and it is E, what gears do I have, I'm think 3.08s.
02-09-2006, 01:26 AM
RE: What gears do I have?
If it helps any I'm at about 2300-2350 rpms doing 75 mph.
02-09-2006, 02:20 AM
im pretty sure E is a 3.27 or something like that and should have a posi trac (limited slip) rear end so u got a good rear end
02-09-2006, 02:24 AM
In case someone has already changed the gears use this link to calculate ratio
http://www.corral.net/tech/gearcalc.html
02-09-2006, 02:36 AM
I've got an AOD that chart doesn't work for me, it's only for manual transmissions.
02-09-2006, 02:40 AM
Assume you have 1:1 in third gear and then pick any trans combo that is 1:1 in 4th gear.
02-09-2006, 07:40 AM
273 is stock
327 is the optional gear from the factory for AODs
yes youre car has 327s
02-09-2006, 11:01 AM
Ya I know, it's one hell of a lot better than those 3.73s.
02-09-2006, 11:43 AM
Actually, it's not. 3.73's would be quicker.
02-09-2006, 11:55 AM
+1 How are your 3.27's better than 3.73's in an AOD?
