head questions
head questions
im looking to order a set of heads for my car. ive basically decided on the afr 165cc...but im a compleet nüb when it comes to a lot of car stuff. pretty much learning as i go. so i was wondering if any of yous mustang maestros out there could help me out with a couple questions.
-stud/pedestal mount --what exactly do i need to know about this in reference to a 1983 engine, which is better¿
-58cc/61cc --whats the difference here, obviously 61 is bigger, but what does this number refer to, and what are the benifits of one over the other¿
--my car is already desmogified, are the non emissions ok to get
--is the 185 too much head for a daily driven, carbd vehicle¿
im probably going to get them from this place, decent price + free shipping....any comments, better deals¿
does anybody have any personal experience with the afrs and a different brand, edel, tw, etc...if so what did/didnt you like about the heads in comparison¿ if all you have had done was gone from stock to aftermarket, no need to tell me a certain brand was a vast improvement over stock....ive got the stock 83 heads on my engine, e7s would be a vast improvement over what i have now.
any other useful info is appreciated. thanks
RE: head questions
I'd get stud mount and buy some roller rocker to use with them. I'd definately get the 58cc and not the 61cc. It's not so much the compression issue as it is the chamber design. I do not believe the AFR 185 is too much for a daily driven carb car. And 185s for $11 more? Go with those. Is this an aftermarket shortblock or stock shortblock though? The 185s don't work on stock shortblock from 87-up. I don't know about an 83 motor.
As far as all the other heads go, I prefer a Twisted Wedge and because it's cheaper and I think they work just as well on most combos. The AFR 185s will do a little better though on more aggressive combos comparing both heads OTB.
RE: head questions
i did notice the price difference between the afrs , usually around 1300-1400, and edels and tws, both around 1000-1100.
i assumed this was due to the cnc machining done to the afrs. does this justify the 300$¿
RE: head questions
ORIGINAL: Jared_blown5.0
talk to pro mustang preformance, he will tell you everything you need to know, and he also offers comp cams brand head called rhs, and the rhs is equivelent to the afr 165 cc.
RE: head questions
ORIGINAL: FullAuto
you may need to notch the pistons for the 2.02 intake valve, but I personally have a set of AFR 185's on my stock rebuild shortblock, but I do have some speedpro pistons though.
RE: head questions
ORIGINAL: silver91gt
RE: head questions
ORIGINAL: razarr69
how come the afr 185s don' fit on a stock shortblock?
RE: head questions
Hi,
You should consider a set of RHS 180s. They flow better than the AFR 165s and offer more power right out of the box.
"-stud/pedestal mount --what exactly do i need to know about this in reference to a 1983 engine, which is better¿ "
Stud mount will offer more strength and reliability.
"-58cc/61cc --whats the difference here, obviously 61 is bigger, but what does this number refer to, and what are the benifits of one over the other¿ "
This refers to the chamber size. The larger the chamber size, the lower the compression. If you plan on going with any form of forced induction in the future, go with the larger chamber. If not, the smaller will give you more power right now.
"--is the 185 too much head for a daily driven, carbd vehicle¿ "
Yes
Let me know if you have any questions, I'd like to help.
Yes
