302 Bore ?
ok does any one know how much it would cost me to bore my 302 0.030 over? and how much of a difference will it make if i want to use the stock stuff? will it even be worth it or should i buy new pistons and rings?
usually like 50-75$ per cylinder- yes its worth it if you're buying new pistons anyway- sometimes a high mile motor can't just be honed to straight, it must be bored and then honed. I would bore.
ORIGINAL: angcobra
you can not use stock pistons/rings if you bore it .030 over.
tinman are you talking about acid dipping when you said real hot tank?
ill have to look around and see how much i cheap i can find.
And i heard the best way is to send it to them with the pistons that you bought so they can make sure they all fit is that true?
