which of these two cams should i put into my baby...
i want good torque and for her to keep pullin on the top end, should i get the first cam?
397-M-6250-B303 Duration': 224°/224° @ .050'
Lift: .480'/.480'
Trans: 5-Speed
Notes: Fair Idle, Good Low-End Torque, Significant Top-End Power Above 4,000 RPM
$169.99
Add to cart
Add to wish list
View Image 397-M-6250-E303 Duration: 220°/220° @ .050'
Lift: .498'/.498'
Trans: 5-Speed/Automatic, Emissions Legal (E.O.#D-225-16) with 5-Speed
Notes: Good Idle, Excellent Low- and Mid Range Torque, Great for Superchargers.
Lift: .480'/.480'
Trans: 5-Speed
$169.99
Add to cart
Add to wish list
Lift: .498'/.498'
RE: which of these two cams should i put into my baby...
true, but other cam companies produce cams like that as well. To try to answer your question, the E cam will be "more fun" to run on the street in the lower RPMs, but the B cam will give you a better 1/4 mile time and stronger top end
