best way to pull engine
Old Feb 14, 2006 | 12:22 PM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: best way to pull engine
make sure you pull your radiator before you try to pull the motor.... i watched someone put their clutch fan right through it
Old Feb 14, 2006 | 12:34 PM
88BlueGT's Avatar
88BlueGT
ORIGINAL: hotstang97gt
well all of the engines that ive pulled ive pulled them with the tranny attached. before you pull it mark where every this goes that you take off and any nuts and bols bag and mark with a sharpie, any thing else might just smuge and you wont know where it goes to. nad no you dont have to mess with the k member to take the engine out. only thing on the k member you do is the engine mount bolts. what you doing with the engine? a rebuild or new engine?
DONT FORGET THAT!!! Trust me, you do NOT want to learn the hard way and have a whole motor/tranny bolts sitting in bags that arent labeled because the marker came off. Use NOTHING but a black sharpie. Also, like everyone said, just take your time and take lots of pics of everything and you should be OK.
Dont forget to clean everything before you put it back on. If your pulling the motor you mind as well clean it all up before you put it back together
Old Feb 14, 2006 | 07:00 PM
hotstang97gt's Avatar
hotstang97gt
^^^ exactly i pulled my motor and im cleaning the engine bay and repainting it. so far it looks way better then it did before its not show room condition but still looks good
Old Feb 19, 2006 | 02:13 PM
91lxstang's Avatar
91lxstang
this is what im gonna do here in the next few weeks and i was wondering if there is actually a site that has a step by step procedure for it....
Old Feb 19, 2006 | 03:29 PM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
Like some other guys said. Put all the parts/bolts in a ziplock and mark them with a sharpie. Take some pics for reference and you should be good to go. I pulled the engine with the tranny still attatched. I installed it seperate though. Make sure to plug the tailshaft of the tranny or your fluid will run out when you tip it.
Old Feb 19, 2006 | 09:29 PM
Hidalgo's Avatar
Hidalgo
Disconnect & label everything then yank/re-install the Motor & Tranny in one shot ... Best way in my opinion ...
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
zachary1988
Sep 4, 2015 03:04 PM
Sep 1, 2015 08:16 PM
