Lifters/Pushrods....
Old Feb 13, 2006 | 08:47 PM
Ninety5five0's Avatar
Ninety5five0
Default Lifters/Pushrods....
Since i'm getting diff. heads ( prolly gt40p ) and a diff. cam this means i need new lifters and pushrods....? i think i'm right. These are both based on the lift, correct ?
Sorry, i'm pretty knowledgeless with this. but thanks for all the help
Old Feb 13, 2006 | 08:49 PM
Ninety5five0
Default RE: Lifters/Pushrods....
I forgot to ask.......Do i need to get new rockers too ?
Old Feb 14, 2006 | 12:14 AM
tinman's Avatar
tinman
New lifters, pushrod of the right length and rockers can't hurt.
It's called doing things right instead of 1/2 ---ed......
Old Feb 14, 2006 | 01:49 AM
mattkoly's Avatar
mattkoly
when i got my cam it recommended a specific rocker size (1.7), after i got the rockers I actually had to measure the pushrods for the proper length, then purchase and complete the build.
Old Feb 14, 2006 | 07:47 AM
Quik's Avatar
Quik
depending on the cam the stock pushrods will work
lifters wont need to be changed unless they colapased
rockers will be used
Old Feb 14, 2006 | 11:12 AM
89chatofive0's Avatar
89chatofive0
You Need To Check Your Springs Also, since certain cams require certain amount of pressure due to some crazy lift sizes. At least that is what I was told in shop class 6 years ago.
Old Feb 14, 2006 | 03:24 PM
w8less's Avatar
w8less
since ur replacing the cam u might want to get a new timing chain while ur in there and there only like 60 bucks thats for a double roller neways
Old Feb 14, 2006 | 04:58 PM
gspfunk's Avatar
gspfunk
You don't necessarily need different sizes, but buy a new set of lifters, pushrods, etc, while you're in there so you don't have to pull it apart agian in a month.
...and definitely upgrade your valve springs...not worth the risk.
Old Feb 15, 2006 | 01:02 AM
Ninety5five0
The heads are brandnew and have valve/springs already. So the cam, pushrods, and lifters all have to match the specs of the head ?
Old Feb 15, 2006 | 01:06 AM
Black Snake's Avatar
Black Snake
Not to steal the post but how do you know when your lifters are bad?
