Suspension Mods
RE: Suspension Mods
ORIGINAL: Blue Oval
these springs im looking at only lower it 7/8" in the front and 1/2" in the back, will i need cc plates for that?
K-member brace: pretty cheap, under 100, so that thing just bolts on? should be like a half hour job then right? does it help a lot?
MM has a package, you get the strut tower brace, full length subframes, and a k member brace, for $344 shipped. im thinking i should go with that to start, what do you think
The MM kit is a good start, be sure that you pant the connectors
RE: Suspension Mods
ORIGINAL: roadrunner
344 shipped, Are those bolt on connectors? I need to start looking into my suspension.
the subframes get welded, and the k member and strut tower brace gets bolted
ORIGINAL: SchoolBoy
Bigger swaybars.....
RE: Suspension Mods
ORIGINAL: Twister
1. full legth subframe connectors
2. lower control arms, spend the dough up front to get the good stuff the first time...i hate buying parts twice
3. springs, struts and shocks and camber caster plates, ALL AT THE SAME TIME, you will need camber caster plates for a lowered car and you will need to remove the struts anyways, so why pay for more than one alignment?
4. strut tower brace, K-Memeber brace
5. panard bar
6. torque arm
www.maximummotorsports.com
5. panard bar
6. torque arm
7. U/L rear control arms
RE: Suspension Mods
yeah, I learned a lot from skimming around on MM's site. they actually tell you the spring rates of the springs they sell, too. It's hard to find that on a lot of sites. + you know it's good stuff...they designed it for their race cars.
