Power Pipe Question..
RE: Power Pipe Question..
ORIGINAL: Black Snake
Ok what about the By-Pass valve? That really needed? When it give like a turbo-blow off kinda sound?
I myself wouldnt run one without it, I actually dont think you can run one without it, when you buy the kits they come with one from the factory. I wouldnt want all that pressure and hot air building up in my engine. Steve a awesome place to read all this info on superchargers and Dyno numbers with different combo's is www.corral.net thats where I made all my desicions and schooled myself, search SC trim and there will be loads of info on anything
The basic principle behind the "Power Pipe" is to decrease intake restrictions. Think about it, the less intake restriction, the less vacuum is created inside the blower. The less vacuum, the more pressure.
Same goes for the MAF.
Then on the output side, you've got throttle body and intake manifold and heads both creating backpressure (restrictions) preventing how much air can be shoved in the cylinders at one time.
When Kenne Bell tests their blowers, they use the "Bazooka"... just a 4" diam pvc pipe with no air cleaner on it and a 90something mm MAF... just from going to a 90 mm MAF, they gained 28 hp, add a 90 mm throttle body, and they gained another 22 hp (http://www.kennebell.net/techinfo/fo...-flowzilla.pdf)
ORIGINAL: odogg88
i believe the sc does come with a plastic bypass valves, i think all vortechs do.
No it doesnt, I checked.
http://www.superchargersonline.com/p...10&tabactive=2
See
ORIGINAL: Tims 88GT
a major waste of money, a bbk fender well kit is the same thing pritty much.
Dude on the corral picked up 40 hp-55 Tq at the wheels with a powerpipe, I would like to know what kinda BBk would produce those kinds of numbers?
