Which octane?
Old Feb 17, 2006 | 06:42 PM
billyboy1955's Avatar
billyboy1955
Default Which octane?
What octane gas should I be using in my 90Gt. I have tried them all but do not feel a difference.
Old Feb 17, 2006 | 06:44 PM
Low_5.0's Avatar
Low_5.0
Default RE: Which octane?
If u wanna bump the timing up a bit, you will need to run higher octane, if your timing is set at 10, then regular is fine.
Old Feb 17, 2006 | 06:46 PM
88BlueGT's Avatar
88BlueGT
Bump timing/highter octane = more power
Old Feb 17, 2006 | 06:48 PM
RawGtPower's Avatar
RawGtPower
higher octane is more or less like a fuel injection cleaner. The higher the octane you go, the hotter you run the engine. If you have a stock stang, dont waste money on higher octanes, your car will run just fine on 87
Old Feb 17, 2006 | 06:57 PM
gspfunk's Avatar
gspfunk
The higher octane helps prevent detonation, so it won't help you unless you've bumped your timing up past 13-14....
Old Feb 17, 2006 | 07:55 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: RawGtPower
Sorry but this is wrong. Here read this if want to actuall know about octane and not just what some guy on the 'Net thinks it is.
https://mustangforums.com/m_1019975/tm.htm
msavoia23
12
Jul 7, 2018 12:08 PM
Big Al's 03
Sep 15, 2015 09:05 AM
MasterLanMan
Sep 13, 2015 08:21 PM
Sandmanbjj
Aug 21, 2015 12:38 PM
dragman72
Aug 9, 2015 12:54 AM
