panhard bar?
Old Feb 19, 2006 | 02:07 PM
philly3384's Avatar
philly3384
Default panhard bar?
This is only used for road race suspensions right? i have on on my car and thinking about taking it off for more of a drag setup in the rear . I bought the car with it and seem to have horrible launches with no traciton.
Old Feb 19, 2006 | 03:13 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: panhard bar?
It can be used for either, who put it on your car and why? Whats the rest of your suspension set up, including tires?
Old Feb 19, 2006 | 03:30 PM
w8less's Avatar
w8less
i read on the MM website a torque arm with the combination of their panhard bar will help improve launches
Old Feb 19, 2006 | 05:33 PM
philly3384's Avatar
philly3384
Aliminum adjustable upper and lower control arms subframe connectors, koni struts, bilstein shocks, 315's Nitto DR's
Old Feb 19, 2006 | 05:35 PM
philly3384's Avatar
philly3384
its the kenny brown suspension the guy who had the car before me used it for road course.
Old Feb 19, 2006 | 05:41 PM
JD1969's Avatar
JD1969
In that case it probably needs different springs and shocks as well as a few small adjustments to things like pinion angle and lower control arm angle.
Old Feb 19, 2006 | 06:34 PM
philly3384's Avatar
philly3384
I dont know what to freaken do now .. sell the ****en thing
Old Feb 19, 2006 | 06:38 PM
88BlueGT's Avatar
88BlueGT
DO NOT sell it because your a little confused on what to do with your suspension. Unless you want to sell it to me
Old Feb 20, 2006 | 04:57 PM
gspfunk's Avatar
gspfunk
You can get more drag-oriented springs/shocks for $600-700, probably, and you can sell the panhard rod to get some of that back.
The panhard rod is designed for road racing (I don't know if it would hurt drag racing). It keeps the axle centered under the rear of the car instead of having the side-to-side play that the rear end would normally have under heavy cornering.
Old Feb 20, 2006 | 05:04 PM
FoxRod's Avatar
FoxRod
Panhard bars are good for all racing. It keeps the axle centered like gsp-funk said but not only through corners. It'll help your car stay straight and not want to swerve under heavy load such as drag racing. If you have ever gone to the track and saw a car with a lot of power take off and when the hit second, for no specific reason the back end gives out and they swerve all to hell. It helps stop that. granted you need a ton of power to do that but still.
