shift kit
Old Feb 10, 2004 | 01:48 PM
91LXmustang's Avatar
91LXmustang
Default shift kit
what does a shift kit do and how much do they cost??
Old Feb 10, 2004 | 01:58 PM
71455vert's Avatar
71455vert
Default shift kit
a shift kit makes your shifts stronger & harder you will chirp the wheels at wot going into 2nd for cost they are cheep 50-75 or so & pretty easy to install.
Old Feb 10, 2004 | 03:34 PM
Quik's Avatar
Quik
Default shift kit
mine was 110 it was a transgo. they do more then just help chirp tires. the prevent less slipage in the tranny. any auto should get a shift kit. you dont need to set it to the hardest for every application. i had set mine for the hardest but i only use mine for street/strip use. i can bark the tires at part throttle
Old Feb 10, 2004 | 11:51 PM
Ormist's Avatar
Ormist
Default shift kit
Can anyone explain what a shift kit does? I mean what does it do to make you have stronger shifting? And where do you install a shift kit?
Old Feb 11, 2004 | 12:03 AM
vfast's Avatar
vfast
I ♥ Acer
Default shift kit
it ups the pressure due to different plates,ball bearings,springs,etc
Old Feb 11, 2004 | 01:08 PM
91LXmustang
Default shift kit
when you install a shift kit on your automatic car, do you still have overdrive, or do you have to shift manually all the time.
Old Feb 11, 2004 | 03:28 PM
Quik's Avatar
Quik
Default shift kit
you only manually shift it all the time if you ahve a manual valve body.
a shift kit comes with different springs and you have to drill out a few orafices and plug up others. move some ***** around. its mainly added strong springs to they valve body.
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Explosive
Oct 2, 2015 07:45 AM
