ARE THESE PRETTY MUCH THE SAME KIT?
Series 9000 Cast Ford 302 Small Block
Crank: 302 Main, 3.250" Stroke, 5.400" Rod Length
Rod: 5.400" Premium 4340 Forged I-Beam Rod w/ARP 3/8" Cap Screw Bolts, Full Floating
Rings: 1/16 x 1/16 x 3/16
Crank # Rod # Piston #
9-302-3250-5400-2123 2-ICR5400-927 725.030
(PROBE DISH) 4.030 9.3 8.7 8.1 1-94105-1 $809
Scat Street/Strip SBF 331 Rotating Assembly
larger image
$999.00
Qty:
Scat Street/Strip Rotating Assembly!
Scat Series 9000 Crankshaft, 3.25" Stroke
Scat 4340 5.400 I-beam Connecting Rods, w/ ARP hardware
Probe Forged Flat Top Pistons, Forged 2618, Inline of TFS relief, Floating pin w/ spirlox, wrist pins
Clevite Rod and Main Bearings
File Fit Moly Ring (Manufactures Choice - Perfect Circle, Total Seal)
This kit will support 600hp from your small block Ford!
Dished Pistons available for +$25, other brands and customization are ALWAYS available!
larger image
$999.00
Qty:
RE: ARE THESE PRETTY MUCH THE SAME KIT?
http://www.flatlanderracing.com/scatsr-fordsbcast.html its the 5th one down
http://www.adperformance.com/index.p...roducts_id=211
i know the one in flatlanderracing has dished pistons thats the only difference i can find and i want dished pistons adperformance can add dished pistons for $25 more
also is this the best kit i can get for the money i have about $1000 to spend on a stroker kit and these are the best i could find for the money if you know of anything else could you let me know
I have the SCAT kit being balanced as we speak besides the dished probes.
Besides one being a 331 and one being 347 and both being SCAT, I can't see you going wrong.
come on guys need some help if the flatlanderraing is the same kit as adperformance im goin to go with that and problem get it this week if not then i need to wait till next week to get the one from adperformance
09-16-2015 07:53 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-01-2015 08:16 PM
