i need serious help please
RE: i need serious help please
could be. get a volt meter, and check the voltage of the wires coming out of the tps. positve end goes to the green wire, and negative end goes to the black wire. if you get a voltage of .98-.99 then your fine but if your off, then you can loosen the two tps bolts and turn it until you get the right reading
And check the vacuum line under the plenum,behind the distributor,it plugs onto a fitting under plenum.The one on my daughters car came loose and her 88 gt was doing the same thing. jim
ORIGINAL: jpirate
ORIGINAL: RawGtPower
Throttle positioning sensor. Located on the right side of the Throttle body
Have you tried cleaning the IAC motor? Those are the most problematic for your symptom.
