What should I do next?
ok.. 5.0 .. yes.. many capabilites.. I really am setting my heart to 12's or motor.. but im gonna to shoot for mid 13's first.
Ok, All I have done right now is 5.0 Pro short shifter and MAC cold air intake..
What should I go for next? I want to do something thats not really that expensive but will give me a good amount of power thats noticeable..
throw me some help here guys
RE: What should I do next?
Gears will not actually add hp, but will by far be the best bang for the buck.
You can also get a larger MAF. The stocker is 55mm, so you'd gain decent power by going w/ 75-76mm.
Anybody can install gears, Its a question of doing it right. You well need an in/lb dial torque wrench, Dial indicator and fixture, and a ftlbs torque wrench, A good caliper/micrometer, Bearing puller(s) and a few small pieces of pipe to drive bearings. An install kit should come with the marking paint.
youll need to worry about bearing preload, setting backlash and pinion depth.
Its a fairly involved job, Ive only done it once "on my own" even then I was being supervised. If you dont know what your doing you can really **** it up.
Jim
Jim
gears gears gears. now read all this then decide if you wnat to do it or pay someone else. http://www.angelfire.com/theforce/5o...5ohtech001.htm
