Big Plans,Big Combo
Old 02-23-2006, 05:14 PM
  #31
stanglx2002
stanglx2002's Avatar
Default RE: Big Plans,Big Combo
you are also going to be needing a lot better suspension then stock before you can run that car hard
stanglx2002 is offline
  #32
SunsokuStang
SunsokuStang's Avatar
ORIGINAL: stanglx2002
you are going to need something like these:
http://cgi.ebay.com/ebaymotors/8687-...40838828QQrdZ1
Then you will have to get Braided cable to go from the rails to the gas tank
Yeah there good up to 1000 HP do you know of any company's who has something like this cause i dont have the money right this sec. do you know anything like the ones there that handle that kind of HP but out of a companys site?
SunsokuStang is offline
Old 02-23-2006, 05:15 PM
  #33
angcobra
angcobra's Avatar
Sounds like you want a setup like my 86 GT. It has a NOVI 2000 and at 15# of boost it made over 720HP. I also have a C4 auto behind it and 3.55 gears out back.
angcobra is offline
Old 02-23-2006, 05:16 PM
  #34
SunsokuStang
Yeah im going to do all that before i do this so i'll be all set just got to figure out what all im going to get.
Old 02-23-2006, 05:19 PM
  #35
stanglx2002
bbk, upr, and aeromotive all make fuel rails
Old 02-23-2006, 05:20 PM
  #36
SunsokuStang
ORIGINAL: angcobra
Your running a novi 2000 in your 86? What size injectors do you have? and what intake and heads do you use? and another thing what kind of C4 is it?
Old 02-23-2006, 05:21 PM
  #37
angcobra
angcobra's Avatar
I made 720 HP on stock fuel rails.
angcobra is offline
  #38
88BlueGT
88BlueGT's Avatar
You should just go with an Aeromotive Fuel Kit.
88BlueGT is offline
Old 02-23-2006, 05:23 PM
  #39
SunsokuStang
the aeromotive fuel kit what all does it come with and how much is it?
Old 02-23-2006, 05:26 PM
  #40
angcobra
angcobra's Avatar
ORIGINAL: SunsokuStang
ORIGINAL: angcobra
yes I have a NOVI 2000. With the boost you say you are going to run you can use 42# injectors, if you plan to boost 15# or more you will need 60# injectors. I have Trick Flow Twisted Wedge heads. The intake is a GT 40 lower with Downs box upper. The C4 was built by a local shop. There are only 2 parts that must be changed in the C4 to make it strong enough for 700 HP, that is the input shaft and the planetary gear set (change from 3 gear to 6 gear). Of course the other parts needed in the tranny are appropriate clutches, bands, servo, and valve body. You will also need a torque converter designed for the power you plan to make.
angcobra is offline
Quick Reply: Big Plans,Big Combo
