Do theese bearing look bad to
okay i see it ,,its the one on the right...how do the sides look ,,does it rock back and forth when you but the half side on the crank???ft. to back??..is your crank worn any on that,journal
Replace them do not put extra lube on them and run for broke.Mains are to cheap and hell theyre already out!</P>
And yes those are bad!And while its apart have the crank inspected just for good precautions.</P>
the crank is in the trash 347 kit is the easiest solutuion to my problem, the rod bearings look the same. pistons, rings (.30)and rods are in perfect working order, alonng with a B303 cam if any body wants them CHEAP.
Originally Posted by 86lx
i would just put extra break in lube and run em!!!!!!!!!!!!!!!!! i've had bearings like that once a result of cracked crank.
