Potentially big problem??
Ok, so i bought this 91lx 5.0, i was told that he put 3.73 gears in it. Took it to a shop to have some stuff looked at(not specifically the rearend) and the guy said you might want to check your rear end out. They said something bout they could turn the rear wheels like almost a 1/2 turn before anything caught and that i should have it rebuilt. Well i knew the person i bought it off of and i knew he just put the gears in and new axles cause i was with him when he blew the rearend out at a local track. Keep in mind, i was told this was 3.73 gears with a posi. Well, the other day i parked in my buddys driveway, its on a hill. I put the car in gear, and turned the car off, didnt think bout puttin the ebrake on. Came out like 5 mins later, my car was at the end of the driveway!! Any suggestions on y this happened??
RE: Potentially big problem??
How far did this thing move in the driveway? Is the car an auto or a 5spd? There is now way the car could move more than a foot because that would be physically impossible to have that much lash.
Could be but if things were that loose it would gring and bang and most likely not even move anywhere. The noise woulbe be violent enough to cause you to park it and check it out. That is of course it doesn't have a killer stereo in it.
Well, is it making any noise?
When theres that much backlash you normally feel the pinion gear smack the ring gear when you start to move.
Dont have a stereo, and no real loud noise from anything. The only noise i can attest to is when im downshifting in low rpms (like 1100-1300), especially in 4th-3rd and 3rd-2nd, i get this noise that sounds like its coming from my tranny like something is catching and jerking. Like something is out of place and then it catches or something like that, hard to explain. But i would think that wouldnt have anything to do with my rear end....[sm=dontgetit.gif]
Here is a thought. If the clutch is going south in it it will slip some and here is a little test. Park it in the same drive way and face it down hile. Shhut the car off and place it in second gear. Stay in it and have a coupples guys push on it to see if it will move down the drive way. Don't push hard enough to damage body parts and do not push on the rear bumper as it will damage the paint. If the car does not hold in place you got a weak clutch on its way out.
