Will not stay idling
I have a 87 5.0 that will not stay running, it fires right up, I have changed the plugs, the fuel filter, replaced the gas with preium gas/seafoam treatment, someone told me to replace the injectors or clean them, there are four injectors, correct. Any other suggestion. This car has not been driven in at least 7 years.
RE: Will not stay idling
Unplug your IAC and turn up your idle screw till you get it to idle, then re set your TPS to around .98 volts. Then disconnect your ground and let you car sit for 15 minutes, then plug your IAC back in and then start with all accessories off and let it just idle for 5 minutes, turn off, and then let it sit for a few minutes then restart with accessories on and check your idle.
ORIGINAL: shawnk007
how do you reset the tps?
It seems that many people have trouble with the way their 5.0 Mustang idles. Symptoms are usually a stumbling or rough idle which may be the result of modifications, or any number of other factors that may contribute to the problem. Clogged Emissions Gas Recirculation (EGR) Valves or Idle Air Bypass (IAB) solenoids are often to blame. A bad Throttle Position Sensor (TPS) will cause the engine to “hunt” for a proper idle setting. If you are experiencing idle problems first check the IAB. If it has large amounts of carbon deposits in it you may need to clean it using regular carburetor cleaner. You will have to remove it to do this, DO NOT clean it while it is on the car! If you have checked to make sure that your EGR, IAB, and TPS are clean and properly set and you are still experiencing problems try the following:
1. Clear the EEC-IV’s idle memory by disconnecting the battery for 20+ minutes.
2. Disconnect the Idle air bypass solonoid
3. Reconnect battery
4. Start engine and set idle speed to desired RPM with stop screw on throttle body (900 rpm works great with E303 or larger cam)
5. Turn off engine and reconnect the air bypass solenoid*Optional — set TPS to 0.90 - 0.95 volts (Do not exceed 1.0 volts MAKE SURE!) Use a digital volt meter!
6. Start engine and let it idle for 2 minutes with no accessories on.
7. Turn off engine for two minutes
8. Start engine again and run for 2 minutes with every accessory turned on.
9. Turn engine off again. Your computer should have now re-learned the new idle settings. This procedure assumes that you have a clean IAB valve. If it is carboned up then you may need to remove it and clean it with carburetor cleaner. F.Y.I.:
For people that dont know you have to take off the neg. battery cable first and always put it back on last when disconecting both battery cables.
