Can PCV valves go bad?
Old Jul 4, 2007 | 11:08 AM
Pony 5.0's Avatar
Pony 5.0
Default Can PCV valves go bad?
Please don't verbally bitchslap me too hard on this one but can a PCV valve actually wear out? I was under the impression that as long as you can hear them rattle, they are still good to use. I reused my PCV after cleaning it out with carb cleaner and it still seems to be passing oil into the intake. I will buy a new one as they are cheap but I was just wondering. Slap away!
Old Jul 4, 2007 | 12:02 PM
LTnone's Avatar
LTnone
Default RE: Can PCV valves go bad?
Does it rattle now? Just buy a new one, problem solved
Old Jul 4, 2007 | 12:24 PM
mattdel's Avatar
mattdel
take it out and test it with your mouth. you should be able to suck through it, but you should not be able to blow through it
Old Jul 4, 2007 | 12:51 PM
HACKGT350's Avatar
HACKGT350
yes they can go bad. just pick up a new one they arent expensive
Old Jul 4, 2007 | 01:05 PM
tmajikman's Avatar
tmajikman
It could be the metal breather below the pcv as well, change it out. Mine was totally clogged up. My dipstick stays in like it is suppose to now.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
KingRando
Oct 2, 2015 08:06 AM
ChampInSD
Oct 2, 2015 04:55 AM
lmurf60
Sep 24, 2015 10:07 PM
