Cervini's vs Harwood
Does either of the two place sell good quality hoods? anybody order there hood from one of them. did you have any problems with installation or anything compared to different companies?
thanks!
thanks!
i have a cervinis fiberglass hood with functional scoops and it really is worth the money, its light, uses factory hing and hood prop which is really nice. i say get one!
^what mine looks like(did the black myself along with the "302" stickers.
[IMG]local://upfiles/73437/EE6AEFEA6E5344158B6CCC6F5CA282FC.jpg[/IMG]
I have had X2 Cervini 3" cowl for fox's & X2 Harwoods, 3" cowl & just installed a 4" cobra R on my 95 GT. The Harwoods had and inch of extra material that needs to come off! (I dont recall this on the Cervini) But both are 1st class and fit almost perfectly if you takesome pride and install them right.
I am pretty sure they are the only 2 that have finished under sides for in the $500/$600 range.
Not a great pic, but here's a 3" pin on cowl hood from Harwood. Does need to be trimmed slightly because it sits a tad higher than the fenders, but outside of that fitment is pretty darned good. To be as light as it is, it holds up fairly well. Apparently, this one has came off the car twice when the pins came out. All it has is a busted corner and a chip on the cowl. Easily fixed. Didn't even crack.
just took some more pics for you, sides, underside, hinge, and the rear heat extractors, sorry for the dirtyness under the hood, havent had time lately to get a very nice cleaning that it needs bad lol
http://s6.photobucket.com/albums/y22...0drifter/hood/
edit: the gap from the hood and the fenders is cause the hood is popped, just so you dont think its bad lol
ORIGINAL: Shelty
cervinis is expensive, but their quality is amazing. you can basically take it out of the box, bolt it on and your good to go...unless you wanna paint it first[&:]
JMO and experience, +1 if you've had a good one but mine was more than terrible especially dealing with who I talked with.
-Jeff
