Whats the difference between the 95 GT and the 95 cobra?
RE: Whats the difference between the 95 GT and the 95 cobra?
1994/1995 5.0L Cobras
Available only in Rio Red, Crystal White and Black
Info:
·240 hp @ 4800 rpm's
·285 ft-lbs @ 4000 rpm's
·Under rated power from the factory
·17 mpg city/25 mpg highway
·15.4 gallon fuel tank
·3350 lbs
Engine/transmission:
·T-5 manual 5 speed tranny
·3.08 gearing
·Cast iron GT40 heads
·Cast aluminum Cobra intake manifold
·Crane 1.7 rocker arms
·60mm throttle body (93 foxbody Cobras came with 65mm)
·70mm MAF
·24lb fuel injectors
·Cobra specific ECU (compensates for the 24lb injectors)
·"Cobra" stamped valve covers with build sticker and signature
·Engine oil cooler
·Front mounted power steering fluid cooler
·Lightened flywheel
·Phosphate coated transmission gears
·Overdriven water pump pulley
·Cobra specific camshaft (very torquey)
Suspension/Brakes:
·13" Front brakes
·11.65" rear brakes
·"Cobra" embossed front calipers
·Front dual piston calipers
·Cobra specific brake booster
·Cobra specific rear sway bar
·Cobra specific shocks/struts/springs
·K-member that is slightly stiffer than the GT's
·No strut tower brace
Interior:
·Steering wheel center / Airbag cover embossed with "Cobra"
·White faced gauges
·160 mph speedometer
·"Cobra" embroidered floor mats
Exterior:
·Cobra specific 17" wheels
·Cobra specific rear spoiler with built in LED integrated 3rd brake light
·Uniquely blistered hood
·Snake logos on both fenders
·Cobra specific front bumper cover
·SVT emblem on deck lid (95 only)
·Cobra emblems on front fenders (no 5.0L emblems)
·"Crystal" (clear) headlights
·Round cobra specific fog lights
·No license tag indentation on front bumper
Info:
·3350 lbs
·3.08 gearing
·70mm MAF
·Engine oil cooler
·Lightened flywheel
Suspension/Brakes:
·13" Front brakes
·11.65" rear brakes
Interior:
·White faced gauges
Exterior:
mrappe
09-26-2015 10:16 AM
mungodrums
Suspension
09-24-2015 10:12 PM
