331 twin turbo coupe-any suggestions?
check out my photobucket link to see my coupe project. i cant load onto mf it says files are to large.but anyway, i have the dished kb forged pistons that give me 8.9to1 with 64cc heads.steel crank,rods are bushed fit with spiral locks,king chamfered bearing mahl file fit rings,twin 45mm turbos with stainless headers. im going the blow thru route hence the weiand 7515 intake.im running the f cam and have the main girdle/windage tray on the way.im also going with the c4 trans so i dont have to lift.i just finished getting the reverse manual trans brake valve body from PA,and full race rebuild kit,servo,flexplate and dipstick tube all from performance automatics. e-bay is great.im hoping with dart pro-1 heads,putting down 550hp to the wheels, along with 3.27gears and 275-60 15 dr's.should be fun.
RE: 331 twin turbo coupe-any suggestions?
learn to use imageshack.us that way you can post the pics in the forum. get some work done and take better pics.
for suggestions......RUN AN INTERCOOLER THIS TIME!!!
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
