1-d-1 shuffle
Old Jul 16, 2007 | 05:46 PM
86 GT 5.0's Avatar
86 GT 5.0
Default 1-d-1 shuffle
My car won't do it... I have it in 1 put it in d and then put it back to 1 after it shifts then it just goes back to 1st gear... Is there a problem or is my trans ok.. I don't doit that often just every once and a while
Old Jul 16, 2007 | 06:11 PM
Foxbodyforever's Avatar
Foxbodyforever
Default RE: 1-d-1 shuffle
is this supposed to go from first to second and then third? sorry, always wondered what 1-d-1 was
Old Jul 16, 2007 | 06:12 PM
shawnk007's Avatar
shawnk007
your probably just not going fast enough........
Old Jul 16, 2007 | 06:22 PM
5.0stanger's Avatar
5.0stanger
What is going from 1-d-1 good for? Why?
Old Jul 16, 2007 | 06:40 PM
BlackLX's Avatar
BlackLX
Unless you want to ruin your trans for good I would stop doing it.
Old Jul 16, 2007 | 08:51 PM
shawnk007's Avatar
shawnk007
Its used for carrying out the 2-3 shift
Old Jul 16, 2007 | 08:54 PM
stang8689's Avatar
stang8689
bye bye torque converter, been there showing off for a chic, she wasn't impressed when we had to walk.
Old Jul 16, 2007 | 08:55 PM
shawnk007's Avatar
shawnk007
bye bye OD band........
Old Jul 16, 2007 | 09:55 PM
creekrat's Avatar
creekrat
1-d-1 just lets you control the shift point from 2-3. The trans will downshift to 1 if you are not keeping it under hard load. However it is not supposed to up shift into 3(D) unless you manually move the shifter into that position. It may be hard on the trans tho, at least acording to all the chimers in.
Old Jul 17, 2007 | 07:49 AM
92hatchLX's Avatar
92hatchLX
My trans builder isn't very worried about the 1d1 shift, he does it on his and doesn't have anyissues.TCI makes their valve bodies and reccomends that you do the 1d1 shuffle.
