4 lug to 5 lug conversion
Greetings. I met someone in passing who converted his 91 Mustang front from 4 lug to 5 lug.
He changed out the rotors. I am not sure what he used to convert. Maybe someone here knows
Thanks.
Thanks.
RE: 4 lug to 5 lug conversion
there are kits or DIY write ups all over the internet. you can find them easily, just type in google. 5 lug conversion mustang. you'll find so many write ups that have all th same stuff
If he just changed the rotors he used Lincoln Mark 7 rotors and most likely Ranger left axles in the rear.
I used '94 Mustang v6 spindles, calipers and rotors and '86-'92 Ranger axles and drums.
The Ranger driver side axles and 9" drums for the rear and Lincoln rotors is the cheapest way. It will limit your wheel choices though because of the hubs on the front rotors. The SN95 front parts will allow you to run more wheels choices. If you were doing an aftermarket race style wheel like a Weld or Centerline, I'd use the Lincoln rotors. If you were wanting to run most of the "Ford" wheels like Bullits or something, you'll need the SN95 stuff.
Thank you for all of your help. I want to install cobra style rims on my 90 LX.
Does anyone know if I install Mark VII calipers on the stang will the rims fit?
ORIGINAL: zeekstr
They look better on my Aerostar
and I belive the 94 17" split 3 spoke.
I am using the 96 17" GT's and even with a 5/16" spacer the hubs are too deep to use the center caps I had to get creative with mine.
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
11-10-2015 11:39 AM
