Cobra Grill Insert
Old Aug 9, 2007 | 11:14 AM
BlessedHellride's Avatar
BlessedHellride
Default Cobra Grill Insert
I am thinking of buying one of those Cobra grill inserts for my Naughty Notty. What are the con's if any that goes along with them and how hard are they to install.
Old Aug 9, 2007 | 02:32 PM
only90s's Avatar
only90s
Default RE: Cobra Grill Insert
If you are brave enough to cut the stock bumper then it is pretty easy...all you have to do is get it painted to match and then it will stick on with double sided tape usually...
Old Aug 9, 2007 | 02:48 PM
tortugasmoker's Avatar
tortugasmoker
its that easy? can u put the cobra insert in the lx grill?
Old Aug 9, 2007 | 02:55 PM
only90s's Avatar
only90s
I have seen LXs in mags with the Cobra Insert..so you must be able to cut the bumper so it fits....'
I had a body shop do mine because I was too nervous to cut my new front bumper
Old Aug 9, 2007 | 04:18 PM
BlessedHellride
If that is all it takes then that is no problem. I have to very close friends that happen to be body men. They have taught me all that I know about body work. I don't mind cutting the bumper and making it fit correctly, I can handle that. I do not like the idea of it being held on by two sided tape. That sounds like a worm doing that installation. Ever heard of epoxy? Try it out, I think you may like it. They offer many different kinds at different levels of strength.
Old Aug 9, 2007 | 04:56 PM
PJB's Avatar
PJB
I cut my stock grille off my LX with a cutoff wheel and plan on using double sided tape on the sides and screws on the top to hold it in once the car is painted.
Old Aug 9, 2007 | 05:01 PM
BlessedHellride
It sounds easy enuff. I don't see why I could't handle it. I wished I could see one that had been put on a car to see how the grill inserts are made as compared to factory fitment.
Old Aug 9, 2007 | 05:31 PM
PJB's Avatar
PJB
The insert actually fits over the bumper.
Old Aug 9, 2007 | 05:34 PM
tortugasmoker
ORIGINAL: PJB
that looks pretty good.
Old Aug 9, 2007 | 08:06 PM
raven_ghostwolf's Avatar
raven_ghostwolf
LX + Utillity Knife + Doublesided 3M Tape + Cobra Grill Insert =
