fix the damn server this site is f'd up
RE: fix the damn server this site is f'd up
Looking it voer, your ping times are geat. There's no real latency there at all. I only start to worry about broadband when it gets over 100ms. However, I do notice one thing...
Easly on in the traceroute, comcast seems to be dropping packets. When you see the * it means that information was not returned. Sometimes, that's due to firewalls, certainb servers, etc. (like your fsecond"hop" for example.) But the second and third both show packet loss while also letting some information through, thus the replies you got from them showing 1/3 got lost and 2/3 got lost. That would result in hangups, slow times, etc.
Of course, that could just be a coincidence. Run it a few more times and note how many times you see packet loss along those hope. If it happens a lot and you're getting slow times, that could be the "traffic jam"
Here's one more thing I want you to try. I want you to "ping" mustang forums, but I want it to ping it like 50+ times in a row to see how many of the 50 packets get through. Here's how to do that.
First, open the command prompt again. Then type this command without the quotes:
"ping -t www.mustangforums.com"
Again, dont forget the space after the "ping" and after the "-t"
That will keep pinging it and giving results until you tell it to stop. You tell it to stop by hitting "CTRL and C at the same time. Then cut and paste those results.
k. every time it times out, that's usually due to a conncetivity issue or packet loss. In the end when you hit CTRL C, it will tell you how many packets were lost. When it's timing out or having problems is when you'd have problems connecting to teh site or problems "hanging."
After you're done, try running a trace route or the ping to another site like yahoo.com, etc. See if the same "hops" give you the same problems. If so, then you can narrow down the problem.
Microsoft(R) Windows DOS
(C)Copyright Microsoft Corp 1990-2001.
C:\DOCUME~1\JERK>ping -t www.mustangforums.com
Pinging www.mustangforums.com [209.234.248.15] with 32 bytes of data:
Reply from 209.234.248.15: bytes=32 time=39ms TTL=109
Reply from 209.234.248.15: bytes=32 time=40ms TTL=109
Reply from 209.234.248.15: bytes=32 time=45ms TTL=109
Reply from 209.234.248.15: bytes=32 time=46ms TTL=109
Request timed out.
Reply from 209.234.248.15: bytes=32 time=38ms TTL=109
Reply from 209.234.248.15: bytes=32 time=37ms TTL=109
Reply from 209.234.248.15: bytes=32 time=41ms TTL=109
Reply from 209.234.248.15: bytes=32 time=49ms TTL=109
Reply from 209.234.248.15: bytes=32 time=52ms TTL=109
Reply from 209.234.248.15: bytes=32 time=47ms TTL=109
Reply from 209.234.248.15: bytes=32 time=42ms TTL=109
Request timed out.
Reply from 209.234.248.15: bytes=32 time=50ms TTL=109
Reply from 209.234.248.15: bytes=32 time=43ms TTL=109
Ping statistics for 209.234.248.15:
Packets: Sent = 119, Received = 117, Lost = 2 (1% loss),
Approximate round trip times in milli-seconds:
Minimum = 37ms, Maximum = 52ms, Average = 40ms
Control-C
^C
C:\DOCUME~1\JERK>
Request timed out.
Request timed out.
Control-C
^C
C:\DOCUME~1\JERK>
The packet loss doesn't seem too bad. Of course, I hate ANY loss, but it only seems like a 1% loss. How does that compare to other sites you ping? (yahoo, cnn, etc)
i tried this for the heck of it at my work computer. every request timed out for the first 100 requests not one gets through. what does that mean? is it their security? this comp is really fast and i dont have trouble loading anything.
heres yahoo samseed:
C:\DOCUME~1\JERK>ping -t www.yahoo.com
Pinging www.yahoo-ht3.akadns.net [209.131.36.158] with 32 bytes of data:
Reply from 209.131.36.158: bytes=32 time=32ms TTL=50
Reply from 209.131.36.158: bytes=32 time=31ms TTL=51
Reply from 209.131.36.158: bytes=32 time=33ms TTL=50
Reply from 209.131.36.158: bytes=32 time=31ms TTL=50
Reply from 209.131.36.158: bytes=32 time=30ms TTL=51
Reply from 209.131.36.158: bytes=32 time=42ms TTL=50
Reply from 209.131.36.158: bytes=32 time=32ms TTL=51
Reply from 209.131.36.158: bytes=32 time=34ms TTL=50
Reply from 209.131.36.158: bytes=32 time=33ms TTL=51
Reply from 209.131.36.158: bytes=32 time=30ms TTL=50
Reply from 209.131.36.158: bytes=32 time=36ms TTL=51
Reply from 209.131.36.158: bytes=32 time=45ms TTL=51
Reply from 209.131.36.158: bytes=32 time=38ms TTL=50
Reply from 209.131.36.158: bytes=32 time=49ms TTL=51
Reply from 209.131.36.158: bytes=32 time=34ms TTL=51
Reply from 209.131.36.158: bytes=32 time=35ms TTL=50
Reply from 209.131.36.158: bytes=32 time=41ms TTL=50
Ping statistics for 209.131.36.158:
Packets: Sent = 66, Received = 66, Lost = 0 (0% loss),
Minimum = 30ms, Maximum = 49ms, Average = 32ms
Control-C
^C
C:\DOCUME~1\JERK>
Control-C
^C
C:\DOCUME~1\JERK>
