351 question.
Old Aug 14, 2007 | 11:16 AM
ReQui3m's Avatar
ReQui3m
Default 351 question.
Can a stock 351 fit into a 95 5.0 gt? if this has already been posted just point to where it's at, i'll go from there.
Other question, is a 302 2 or 4 main bearings?
Old Aug 14, 2007 | 11:34 AM
FivePointOhh's Avatar
FivePointOhh
in limbo
Default RE: 351 question.
302 = 2 bolt main stock. yes a 351 will fit in your 95 gt. for specifics you might want to post in 351 section. there is a sweet write up on how to make it fit and work and all that is needed for the conversion, i dont remember what site it is, ill see if i can find it.
Old Aug 14, 2007 | 11:45 AM
w8less's Avatar
w8less
yep its called the 95 svt cobra R
http://www.mustang50magazine.com/tec...wap/index.html
that is a good link
Old Aug 14, 2007 | 11:46 AM
w8less's Avatar
w8less
ORIGINAL: ReQui3m
most 302 blocks are 2 bolt but there is always the very rare boss 302 block and it was a 4bolt
Old Aug 14, 2007 | 04:07 PM
creekrat's Avatar
creekrat
Only on the 3 internal caps not the front and rear.
Old Aug 17, 2007 | 10:26 AM
ReQui3m's Avatar
ReQui3m
Sweet thnx!
I was sure if i should post it in this part of the 351, so i just tried it here. Do you guyz know of any complications with swappin a 351 in?
Old Aug 17, 2007 | 10:34 AM
w8less's Avatar
w8less
hood clearences and your headers will more than likely hit the steering shaft.
if you buy the correct parts it should be fine
Old Aug 20, 2007 | 12:12 PM
ReQui3m's Avatar
ReQui3m
Ok is the svt cobra r the ONLY 351 that will bolt in?
Old Aug 20, 2007 | 12:18 PM
w8less's Avatar
w8less
no any 351 will work if you have the proper parts.
that cobra r and the s351r and r code were just factory mustangs that came with the 351
tmdm
May 2, 2021 02:49 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
Mustangs of Illinois
Aug 22, 2015 10:00 PM
89blueslug
Aug 10, 2015 07:20 AM
