short shifter install
RE: short shifter install
real easy
1. Remove center console
2. Remove shifter ****, boot and hold down bracket.
3. Remove the 4 i think 13mm bolts for the shifter. It will be sliconed down so you have to work it.
4. Clean old silicone off after covering the hole, add new silicone and install.
i would change your fluid while you have it apart
These are the instruction Steeda has on the installation for there Triax, should give you everything you need. http://www.steeda.com/directions/
You'll need Adode to read the Steeda file, if you don't have Adobe Reader you can go here for a free Download..http://www.adobe.com/products/acrobat/readstep2.html
09-03-2015 07:14 PM
